It is currently Sun Jul 20, 2025 10:04 pm
PostPosted: Wed Jun 14, 2006 4:19 am
Just came across this posting by "the maestro" Frank Ford on the AG Luthiers Forum:
"By the way, you DO sand spruce across the grain, yes?
Block sanding with fine grits across the grain reduces the tendency to scar and dig out the soft grain between the hard lines, and results in a finer, flatter surface. Scratches from fine cross grain sanding don't show in spruce. If you haven't - give it a try. . . "
This is definitely in the learn something completely new category for me. Any of you OLF'ers already do this?
PostPosted: Wed Jun 14, 2006 4:46 am
This is propably true with 320-400 and higher but would not try this with 220 or lower. The depth of the scratches would cause an issue I would think. I have and will continue to sand raw wood with the grain. It is just what I was tought from my grandfather.
PostPosted: Wed Jun 14, 2006 4:51 am
Oh, yeah, Dave, I started doing it this way about two minutes ago!
Makes sense for something as soft as spruce with that hard grain part. I'll surely give it a try.
PostPosted: Wed Jun 14, 2006 5:09 am
I have found that using a wooden sanding block with, say, 220 grit paper and sanding against the grain is really the only way to get rid of the ridges that tend to accumulate because of the grain lines. I don't do this on the whole top, though, just the spots where the ridges appear, which are usually on the edges of the top, and often the result of scraping/sanding down binding and purfling.
Best,
Michael
Live to Play, Play to Live
I've read that any scratches that do show from this cross-grain technique look like "silking" under finish. Again, that's only what I've read, not from personal experience; but apparently some people do this just for that effect.
PostPosted: Wed Jun 14, 2006 5:48 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Cool! This has had me befuddled for some time! I'm gonna try this as soon as I get home!
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Wed Jun 14, 2006 6:15 am
Good timing Dave,
I have just closed the box on my latest and will be pondering just such things as this.
Good one.
Wade
Wade
Nashua, NH
http://www.wadefx.com
PostPosted: Wed Jun 14, 2006 8:01 am
First name: Nelson
Last Name: Palen
I've found that sanding across or at least at an angle to the spruce grain works much better also in the recurve areas of an archtop. I do this when a little material removal is needed but usually end up going with the grain when final sanding (220 grit) prior to applying finish. Seems like some of the same factors may apply here as when feeding a workpiece thru a drum or belt sander at an angle?
Scraping soft wood such as spruce sometimes works better if done at an angle also to avoid tearout.
Nelson
PostPosted: Wed Jun 14, 2006 11:10 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
I just tried this on a dread I'm getting ready to finish, and lo and behold, it works! Another obstacle overcome!
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Wed Jun 14, 2006 11:52 am
You know, John Watkins turned me on to this idea. His theory, and it makes total sense, is that if you are going up in grits, it won't matter if you have cross grained scratches because you'll work them out with the next grit.
It's worked out pretty well for me.
